Scott
The weights on the corners are just a starting point..... and you need a starting point.... but once you put the car on the ground and hook up the sway bars and drive it .....
The tire temps will tell you what to do to the Spring once you come off of the track.... they will also tell you what to do to the camber or toe.....
And after a short period of time you will know what to do by the way the car is handling....
Morris
Morris
