Old 07-20-2004, 01:11 PM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Hi Bob:
Do you know how many DC Amps the single puller fan (mounted) behind the radiator draws? Mine is circa, 1992 - ish as my ERA is number #375. The only insignia on it says "Made in Canada" from what I can see. It is a single fan with paddle blades connected to a circular rim (which turns with the blades).
Reason I ask is that I am wondering what the total AMP draw will be when all 3 fans are humming along? My Bosch Fan Relay is a number 0 332 002 156 which I think is a 30A relay.
I suspect I will be okay with all the fans on one circuit. My particular fan wiring does not have the auxiliary pusher fan plug up front for the pusher fans. Maybe you guys added that feature to the harness after my car was made or perhaps it was removed? However, adding that to the existing wiring would be easy to plumb up.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
