Old 07-22-2004, 08:06 PM
tblackgt350 tblackgt350 is offline
You are exactly right concerning this linkage; I knew the carbs weren't opening at the same rate, I just couldn't figure why. I do not think it is possible to mount the carbs back to back(all fuel lines on the outside) and use aside pull linkage with optimum results. Once I got a set of reversing plates that allowed me to mount the carbs facing the same way, with all throttle levers pointing up, the synchronizing became pretty easy.
A good friend will help you move.
A real good friend will help you move a body.
