Old 07-23-2004, 04:54 AM
traindriver traindriver is offline
Cobra Make, Engine: SPF #1591 / Perf.Eng. 351W/48IDAs
gt350,
You can do a side pull using 2 bellcranks, but then you have to start worrying about slop.
Here's a pic of a Pierce center bellcrank on a front to front FE set up, if you reverse the bellcrank and have it pull from the left, the rod should end up close enough to you next link at the firewall. You may have to extend your actuator a bit but it should work...It better, that's my plan for my SPF.
Chuck
