Old 07-24-2004, 11:26 AM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
Do not take this wrong but are you sure you have the pump hooked up correctly? Some of the after market pumps come with fittings and I have seen some hooked up with the inlet on the carb side and the outlet on the tank side. Of course the car will never start.
Have you tried putting a small amount of gas in the carb? You can prim most by putting a bit of fuel in the carb by way of teh air vents on top of the bowl.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
