Old 07-24-2004, 02:18 PM
pgermond's Avatar
pgermond pgermond is offline
Try pushing rather than pulling - wrap a rag round an air hose for a seal and blow air in to your fuel tank. The pressure will build and push the fuel all the way to the carb. If you have a double feed Holley, pull the plug on your fuel bar, or disconnect the fuel line from the carb (the pressure could screw up your jets). Remember - VERY IMPORTANT - it doesn't take much pressure in the tank to move the fuel through the lines and fuel pump - so go easy - you're not blowing up a tire.
Good luck!
Phil
http://www.uniquecobra.com/
