Old 07-24-2004, 08:36 PM
MrMagoo's Avatar
MrMagoo MrMagoo is offline
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Send a message via AIM to MrMagoo
Yeah, I suppose that the pin is engineered to sheer at a certain level of resistance. Hmmmmm....
The distributor shaft gear looks fine, no apparent damage.
BTW I have a melling hi-volume oil pump, I wonder if the hi-vol version of the pump creates more resistance? Also, I am running Castrol 20w50 synth oil.
One peculiarity of my engine build is that the oil temp has always been on the high side, especially when in the higher RPM range. like 250 F to 275 F. Water temp is very cool, around 150 F to 180 F.
If I can see you, I'm too close
