Old 07-24-2004, 09:36 PM
poorboy poorboy is offline
With the McLeod thow out bearing the instructions state with a 3/4" master cylinder you are not to exceed 1" of piston travel. The clearence between thow out bearing and pressure plate should be between .100-.125. Also make sure the fluid line is on the bottom when installed.
Poorboy
