Old 07-25-2004, 04:26 PM
dusty50 dusty50 is offline
Cobra Make, Engine: B & B 302, 5 spd.
Default Battery grounds
RLH,
Whether you run cable from the battery to the starter/motor and motor to frame or run battery to frame/frame to motor, the key to both installations is cleanliness and protection. Make sure the areas that will contact the cables are clean to the bare metal. While there are plenty protective ideas for cable ends, I use fords dielectric grease for electrical terminals. Crimp all cable ends and then solder and as Steve suggest, use heat shrink with the glue on the inside. The solder keeps the harmful gases out of the connector and the heat shrink keeps the elements away. Lastly, dont under any circumstance, ground the battery or frame to the transmission!
Usually works fine for a while, but when the bond between the block and tranny starts to corrode, the ground seeks its path thru the next best thing which is all that shiny metal in the bearings. There have been many cases of trannys gone south with bearings that look like a light duty welder has been working on them for some time.
In the emergency vehicles we work on, we go a bit overboard with grounds and do battery to frame, battery to block, battery to body and block to frame.
Take your time and dont scrimp on materials at this point. It will be well worth it in the long run. Hope this helps, dusty
