I will remove the top arm support and get it milled away through the centre.
I have removed as much of the bump stop metal I feel comfortable with, and in any case that is not where it fouls.
It is contacting about midway between the bump stop and inner pivot.
As you and Mike have said the problem may be in my rubber bushed mounts, but I think I would need to move the top mount backwards allmost 15mm to gain the clearance required.
I will remove the spring from 1 shockie and see how hard it will be to remove the upper mount, it looks like it just screws on.
I most likely wont be able to play until the weekend, we are very busy at work and with end of month comeing up it gets even more frantic
Cruising in 5th
