Old 07-26-2004, 09:55 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Joea,
Just a suggestion. I don't have an ERA so my wiring is different, but I put small terminal blocks on my firewall and ran a ground to one of them and battery to the other so I could just take whatever I need off them for testing. I also used plugs instead of splicing my Jacobs in, so I can just unplug the wires. If your red wire to the MSD is easy to get disconnected, you might try just using a clip cord and hooking it to a source which has 12V when the switch is turned on. You can do this just temporary to see if the car will try to start and you will know for sure that you have battery and ground to the MSD box.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
