Thread: 428 CJ block
Old 07-26-2004, 12:13 PM
Power Surge's Avatar
Power Surge Power Surge is offline
Ok, I have not found any cast numbers, but there's lots of numbers stamped all over it.
On the pass front timing cover area is what looks like "9B20N" stamped in it. On the front lifter valley end rail there are several "3"s stamped. On the little cast pad on the pass front corner there is a "9" stamped. I noticed on the drivers rear of the block there is a cast flat pad, with what looks like 8 digits stamped in it. Could this be a partial VIN? Were the VINs stamped on the blocks? It's hard to make out exactly what the stamping is, as the top portion of all the digits was stamped a bit light and hard to read. That's all I've found so far.
Sal Mennella
