Old 07-28-2004, 06:30 PM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Default NO
No, NO, no.
Use assembly lube like the stuff you get with the bolts.
Increment the torque wrench slowly at 10 pounds per set of bolts until you reach your desired setting.
If aluminum, make sure your put the washers on or you'll be sorry.
