Thread: TKO Clutch fork
Old 07-29-2004, 09:01 AM
joea's Avatar
joea joea is offline
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
I spoke to Doug about it this morning. I did not trim the fork because the end was less 2" wide as described in the manual. I can still do it if necessary but I think the fork will just want to move higher if I do. I an going to try to shim the bracket to get better alignment of the slave cylinder first. The rod threads grinding against the cylinder wall is a bigger issue than the fork rubbing the fiberglass.
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
