  #35 (permalink)
Old 07-29-2004, 08:41 AM
Roscoe's Avatar
Roscoe Roscoe is offline
If the starter is cocked and not square to the bellhousing it can cause excessive wear. If the starter is in too far, or not far enough, it can cause chewed up ring gear. If the gear 'hangs' after starting it can also cause the ring gear to show wear.
What starter/bell housing are you using?
Roscoe
Roscoe
