Old 07-30-2004, 09:39 PM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Just because you put on better flowing heads, doesn't mean you'll get more horsepower. Your cam also has to be able to flow the extra air. Just from reading your post, the cam you want to use, stock heads will pretty much handle all the air the cam is able to flow. You need more lift and longer duration for the bigger heads to come into play....
Jack
XSSIVE .....
