Old 08-01-2004, 05:11 PM
Bruce Edwards's Avatar
Bruce Edwards Bruce Edwards is offline
Cobra Make, Engine: Hunter with a 4.6 supercharged
If you remove a rocker and check the stud were it goes into the head you will see a shiny area at the bottom the stud. You can also check by laying a straight edge across the tops of the studs. If some are lower than others some may be pulling out. You would be looking for a big difference not a small one.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
