Old 08-01-2004, 09:33 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I started checking at the plug at the regulater.I figured that I should have one wire switched by the ignition switch.remembered I had installed a diode on the "I" terminal wire, nothing at tha plug , current on the other side of the diode .Had seats out so I could fit under dash and follow the wires and all.Removed the diode and tested, it still worked must have been in backwards turned around and reconnected TA-DA!
Mike H
