Thread: wiring diagram
Old 08-03-2004, 07:13 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Need a 30 plus amp relay. Unless your fan has problems, this should cover the current draw of the fan. Painless makes a thermal circuit breaker type kit.
This means it will run until either the temp drops or the thermal breaker shuts the fan off.
JC Whitney sells a 70 AMP relay, but you will need to find a pigtail for it.
Hope this helps.
