Old 08-03-2004, 09:24 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
I'll add my $0.02:
Place studs on all bolt holes, 1/4 x 20 and 5/16 on ends.
use locktite on the studs and let dry.
Blue, high performance RTV on one side and use nuts to help hold it in place.
Then coat the pan side after the rtv is set with axel grease. Pless the pan up and run the corner studs on first. then do a swap pattern side to side working from front to rear as you tighten the bolts.
DO NOT squish the gasket out. The grease will seal the pan for years and if you have to pull it again, it just drops off.
Go easy one th RTV as blubs in the oil pan may get loose and clog the oil pickup.
