Old 08-04-2004, 03:21 PM
MOTORHEAD's Avatar
MOTORHEAD MOTORHEAD is offline
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
John; If it was only run in fresh water, or has a raw water/anti-freeze heat exchanger, it should be worth checking further. If it has been run in salt water with out a fresh water cooling system installed since new, forget it !!!!
If its a block thats never been in salt water, tear it down and have your local engine shop pull all freeze plugs and do a visual inspection of the water jackets. ( if they have a borescope, even better!) then they can pressure ck it for leaks/cracks.
There are other tests that can be done ( sonic, x-ray,) but usually
a visual and pressure test is where to start.
But also be aware that marine engines lead a much tougher life than any car engine!!! Boats can't get up to speed and back off the throttle and still maintain that speed like a car can. A boat engine is always going"uphill"!! So be on the lookout for badly worn cylinders and stress cracks in the block.
"Be careful out there"
Ted
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
