Old 08-05-2004, 04:49 AM
CALHOON CALHOON is offline
If it isn't jumping out of the gear it's in, It may be the reverse idler gear attempting to slide into mesh. This could happen if the spring that holds it out of mesh were not fastened at the front of the case( for an older box) or at the anchor post( for a newer box). If it is grinding because it is being pulled from gear, check the crossmember mounting for proper fastener torque/installation.
