Thread: Optima battery
Old 08-07-2004, 08:44 AM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I tried to charge.I was using a 10-2 charger.It got warm and resulting voltage changed little. I removed the battery and ended going to Sears. They put it in a Logic charging and testing unit that had a door over the battery.After programing by technecian,readout said it would take 37 minutes to charge before testing.In a couple of minutes it said 33 minutes,sounds rite..In a minute or so the printer started and it said the battery was good.The tech removed my battery from that machine and tested it on another machine ,12.56 V, sounds good.So I reinstalled. Could the turning it on its side to remove and reinstall have moved something.The car is up on frame stands again .A small oil leak at the remote oil filter .Dinged fitting , replaced fittings and waiting on #10 conical seals.Even located another version of the conical seal locally but no #10's on hand.
Mike H
