Old 08-08-2004, 07:00 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
You have to make sure your engine has oil galleries in the lifter area, as some 427 SO's were solid lifter only, and with these engine blocks, you can't run any type of hydraulic cam. if it is a hydraulic lifter block, it should have oil gallery plugs in the back of the block on each side of the cam plug.
if your block is truly a 1965, I would guess it is a solid lifter block.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
