Old 08-08-2004, 08:47 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Dwain, check the hood latch box upper bolts. The body will sometimes hang up on those. I usually pull them out and drill through the existing holes after the body is down completely. The spring adjusting bolts that Art mentioned will also hang you up if you haven't cut the holes out in the package tray. Also check the tunnel area that sits on the e-brake housing. Sometimes the fiberglass gets a little thick there and the corners get rounded. The body will not necessarily touch all parts of the frame. The rear area needs to be above the frame about 1/2" especially around the rear uprights for the bumperettes.
Don
