Thread: Dash Material
Old 08-08-2004, 09:42 AM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I bought a vinyl cover from EM.When I took it to an appolstier.He poo pooed it saying that he could have made a cover at not much charge .My cover dash +all prepared sand blasted painted still took three weeks and $264.Didn't follow instructions anyway had to alter some myself.Make sure that your holes are big enough to allow for vinyl I opened some of the 2 1/16" holes but the large ones like the Tach and speedo are so tight.Clamps didn't add that much. They will not fall out .The three 2 1/16 gauges to the right ,more centeredof dash I tilted towards the driver with the Morso tilted trim bezels.Had to remove the padding around each gauge and reglue vinyl.They take a slightly oval hole.Do not cut the vinyl for gauges and the like untill it has been stretched and glued. I had to put small thin washers around all the switches and indicater lights that had been pre cut by the appolstier.All the indicater lights that I had from before ended up being replaced.The tabs for holding into dash were for bare metal and didn't conform to a padded dash,depth.If ther was any mistakes to be made or problems , I had at least half of them.
Mike H
