Old 08-09-2004, 07:59 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Dwain, are you sure the motor mount dropped into the slotted hole. The 2 pieces should be flat when bolted together. The mark on the body for the sidepipe cutout is just a guide. I have had to trim a little more at times. You don't need much clearance on the right side. The motor will torque up on the left side and down on the right so you actually need a little more clearance on the drivers side.
Don
