Old 08-09-2004, 07:38 PM
Bill Wells Bill Wells is offline
Cobra Make, Engine: Superformance 156, ex Paxton 351, now a 392 Ford Racing Stroker
mike , check your voltage regulator ground wire. many installs have that ground wire going from the regulator to itself, ie, about 6 inch wire from the reg and grounded to one of the screws that holds the reg in place, and said screw goes into composite non metal surface. try running your ground to your engine or to the frame crossmember area. it worked for me on the block . no more wiggle , except maybe some times at idle, kick the rpms up to about 1000 or so and that will go away. bill.
