Old 08-10-2004, 06:26 AM
Cracker Cracker is offline
My 427 was run at 11.5 and on PUMP GAS ONLY. Everything works fine but the timing had to be pulled back to 32 total. The advantage however is IF I had wanted to go radical and pump up the timing and pour in race fuel I found an extra 30 hp!!!
Through the KCR test we are reducing the compression to 11:1 so the timing can be advanced a little more with standard 93 pump gas but anything less with aluminum heads is just throwing away potential (not that I know anything about this though - I thought that sounded good!) Best wishes and YOUR RIGHT about high compression revving and idleing - nothing beats it!
