Old 08-10-2004, 10:38 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Dwain, the old and new mounts are totally different. Check the mount height or just switch them side to side and see if that changes anything. Are you measuring the sidepipe height to the body or just the opening? If the sidepipe is 1" higher then the rear of the sidepipe will need to be pushed down to install the rear bolt. If it all lines up or if you have to lift the sidepipe to the rear mounting hole then they are correct and the body mark for the sidepipe cutout is off. I would also measure the engine left and right side to see if it is actually higher. It may be an optical illusion.
We received your interior and carpet. Do you want us to ship it or do you want to pick it up?
Don
