Thread: Optima battery
Old 08-10-2004, 09:37 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
The Master switch "could" drain the battery down if it is going to ground in anyway. An Alt shouldn't drain the battery down unless there is a ground issue, where battery power is being siphoned off due to a faulty ground--rare occurance on an alt.
Try charging your battery then remove the neg terminal from it--let it sit overnight or for a day then hook it up--if it shows a near full charge battery is good--if it is dead, battery is dead won't hold a charge---if it is a good battery and dies there is a ground fault drain on it from your wiring.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
