Old 08-11-2004, 03:02 PM
tpiini tpiini is offline
Originally posted by coyled
Tom, the inside is pretty simple on a tremec. I have had this problem before. Each syncro assembly has 3 rectangular detents that engage the gears. These detents break off at the corners from down shifting. It will still upshift ok but will not downshift. I have had this happen on 2 tremecs. When you pull it apart, you will see what I mean. If the syncros were bad it would grind like crazy. Scott
Thanks Scott,
I figured that if the synchro's were "bad" the gears would grind like crazy. That's what has had me confused. Now for the REALLY stupid question: Is there an "upgraded" set of synchro's I can put into it? I don't mind pulling it out & replacing parts, but I really don't want to make it an annual event.
