Old 08-11-2004, 07:36 PM
Art Burtt Art Burtt is offline
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
Yup yup you got it in right. I wonder, if it was upside down would you have 5 speeds backwards and only one forward? Maybe the place where they cut the firewall from the body isn't right. Mine sort of looked like the cut was the same. Is it possible to get a firewall from one kit and a body from another? You'd have to ask Don. Also I had to make a plate to bolt my Ididit column to the cowl bar. The threaded rod I used was sticking up about 1/4 inch too high. Once I saw where it was hitting I lowered the rod and the body fell right into place.Do you have the dash bolted in? Body
goes on, then dash gets bolted in.
