Old 08-11-2004, 09:25 PM
bmcmillan bmcmillan is offline
Cobra Make, Engine: B&B non-donor, 496 Genesis SO (608 HPwith 9.4:1 CR), Tremec TKO, Currier 8.8
Two good sources:
"Ford Performance" Pat Ganahl S-A Design Publishing Co.
"How To Rebuild Big-Block Ford Engines" Steve Christ HP Books
There is some guesswork when mixing and matching parts because the Ford parts numbering system wasn't too good at the time. These books cut down on some of the Voodoo, but even they don't agree on many parts. The FE has a lot of interchangeablilty, but the are some gotchas. For example, a 428 crank needs the 428 balancer, crank, and flywheel as a unit - it is balanced completely differently than the other FE's. If you go to a few high performance swap meets and you are armed with the knowledge in these books, you will be amazed at what you stumble on.
I got 390SP iron heads, an authentic medium-riser dual-quad aluminum manifold, and a 428 crank/pulley/flywheel at the swap meet, wrecking yards, and Recycler magazine.
I thought it was part of the fun building the car.
Brian
