Old 08-11-2004, 09:45 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I was wired as the ERA diagram with lite but no lite."I" wire had a diode before regulater. "A" wire was fused but not switched with the ignition switch .If I left the master switch on it would drain the battery in four days.The alternater repair shop tested my alt and advised to wire as shown in the ERA without lite diagram. I removed the stater wie from regulater to alternater,moved ignition supply (with diode) from "I" to "A"&"S"Time will tell If I fixed the problem it's late and I'll check tomorrow.Where did the power leak out .Please explain what was going on.I'm pretty sure I had left the master switch on but ignition and everything else was off.
Mike H
