Old 08-16-2004, 12:46 AM
grumpy grumpy is offline
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
Alex,
What geometry are you using. If it's base MustangII there are sevral routes from example: $60 to $200 complete for upper arm.
The chassis you selected should have the ears for the suspension, if so, go to the supplier and select their design data/dims, they should have suggestions, then purchase.
If it's original COBRA go the 8840 Comp parts route on the suspension parts and geometry, ADVISE to forget the old AC/Triumph parts route unless it's a purist route.
The front geo should also relate to the IRS rear, same notes apply to that area.
grumpy
