Thread: Photo's
Old 08-16-2004, 08:00 PM
PCC's Avatar
PCC PCC is offline
Flip,
To load a picture directly into the thread, use the "Attach file" tab. Make sure your photo is no more than 40 Mb as otherwise it will not load.
To ensure it is less than 40 Mb open your photo using Microsoft Paint and using the Image tab skew to whatever % to get to less than 40Mb (I start with 70% vertical and horizontal and then save the file - go back to the photo and left click on properties to see the size of the file. If still too big, simply skew again).
Sounds like alot of work, but once you've done it a few times its a breeze.
The other way is to use the http:// tab when writing your thread. This way you don't have to reduce the size of the photo. You simply link it to a web address (title first - web sit second) and then a link will appear in your thread.
Don't worry if you don't have a web site....just load into your gallery and copy the address over into the http tab.
I find the second option tidier.
Finally, to load your photos into your gallery go to your personal settings and upload into your gallery. Just check that it is your gallery and not the general picture area (You'll be given several options as where to load to)
Hope the above helps
PCC (Peter Craig)
Keep the sun shining
