Old 08-17-2004, 01:16 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
In theory they should last longer with a gilmer drive. It's the belt tension that kills the bearings. With a toothed belt you shouldn't need to run as much belt tension as you would with a v belt or serpentine setup. The teeth provide the grip rather than the friction of the belt against the sides of the grooves.
Mike Murphy
Melbourne Australia
