Old 08-17-2004, 07:21 AM
XXQQQME's Avatar
XXQQQME XXQQQME is offline
Cobra Make, Engine: West Coast, Ford 460
trularin,
Thanks for your reply. Following is the series of events that lead to my frantic thread request:
Blew out seals on HTB. (no pedal stop, my fault, lessonl learned)
Dis-assembled drive line, drive shaft, tranny, bellhousing, pressure plate, clutch disc, flywheel.
Discovered that disc was soaked with brake fluid, levers on pressure plate were damaged and ring gear teeth severely damaged.
Decided to replace damaged parts.
Ordered and received parts from Mr. Kee (great customer service!)
Upon re-assembly, It appeared that the Lakewood bellhousing would not work with the new flywheel. Note: the old flywheel had 184 teeth, the new one has 176. Lakewood bellhousing locates the starter out of position. I tried to turn the engine over with coil wire removed and experience grinding noises indicating that something was wrong, stopped immediately. I also took a "modeling clay" impression which showed mis-alignment between starter gear and ring gear.
I found the correct parts at the Mcleod Web page, but as I mentioned earlier, it is not in stock. I was hoping Red at Mcleod might be able to resolve the situation. . . heaven knows I'm willing to pay.
Anyway, I don't think I have any options in terms of a "quick fix" to get my car on the road for the WDC.
Got any ideas! (magic dust!!??)
'bacher
