Old 08-18-2004, 06:51 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Depending on what you are doing will determine type of resin needed. strictlypersonl had a good source I did not think of but if not one in your area, for general use about any type works and is less expensive. also try Home Depot, Ace Hardware. If doing body repair I would use a more expensive but better resin. This is to avoid shrinkage with time and heat, cracking and provide better strength. For body repair a source would be to do search on local yellow pages in business section. Look in the catagory of RESIN, AUTOMOTIVE MATERIALS PAINTS. What are you building anyway?
By the way if you get real itchy from sanding and grinding a Wives Tale that works is oatmeal. it really does work! Get an old tube sock and put a big handfull of any uncooked oatmeal in the sock. Tie the end in a knot so it does not fall out and then wash/scrub area with it. Rotate hot to cold in the shower during process to open and close your pores. This works if exposed too fiberglass insulation in the attic also!
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
