Old 08-19-2004, 02:06 AM
griffinzein griffinzein is offline
Cobra Make, Engine: made mine from molds taken off an original, 302/ 351 heads hand made intake drysump oil system, and lots of nitrous.
Send a message via AIM to griffinzein Send a message via Yahoo to griffinzein
speaking from personal experience the mod you have in your tranny is woth keeping. the 76 cobra II that i run has the same mod. for some reason the T% tranny has a really bad habbit of grinding 3rd gear when you shift quickly. i put 380 lb/ft of torque through mine on a dailey basis and i n the past 4 years i havent had any problems with it.however before i had some teeth ground off 3rd i had to replace it 4 times becuase the grinding was causing the teeth to break off. so if the tranny is beefed up likey ou said i would stick with it, in fact if you have the money to replace the gear you should run it realy hard as is for 2 weeks replace the gear and run it really hard for 2 weeks then tell me which gear you prefer. even though i know you will be putting the ground gear back in the tranny.
Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer inwaht oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist and lsat ltteer be at the rghit pclae. The rset can be a total mses and you can sitll raed it wouthit a porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe. Amzanig huh?
