Old 08-19-2004, 11:39 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Hi Steve:
I have a 428 Police Interceptor, built in 1992 by Danbury Competition Engines. I have an ERA with their standard for 1992 brass radiator cooled by one puller fan (thermostatically controlled switch) and augmented with two pusher fans (manually activated only).
In hot weather I run in the 170 to 180 F range with the puller causing the fluctuation as needed. In fourth gear with the engine revs low, at speed say 60 - 70 MPH the car will stay in the 165 to 170 range.
When I come down from a high speed run to a stop or at slow speeds ~ < 30 MPH, then the temp will climb to 185 or 190. I then will throw on the pusher fans (these, I have put on a separate circuit, Lucas Toggle switch activated) and they will reduce the temp rather quickly in conjuction with the puller fan.
My oil temp gauge is always about 10 to 15 degrees lower than the water temp I have noticed. Pretty much hoovering in the 150 to 180 range.
What does your oil temp gauge read?
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
