Old 08-20-2004, 07:15 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Saying again, use an ATI damper if your budget allows. It is the one currently preferred by professional engine builders. It does the best at what a damper should do . . . damp vibrations. But if you're not going to be turning your engine much over 5,000 rpm, it doesn't matter much which damper you use as long as it's in good condition.
Check out what ATI says: http://www.atiperformanceproducts.co...mpers/testing/
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
