  #23 (permalink)
Old 08-22-2004, 06:14 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Good try, Mike. The Y block was Ford's answer to the SB Chevy. Not too good of an answer, I might say, even though it did have some successes. The Y block got its name from the deep-skirt design, much like the FE's, whose pan rails extend below the crank center. The small block's pan rails are essentially even with the crank main centers.
Again, what was the original name of the small block?
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
