Old 08-23-2004, 05:14 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
Did you form the fitting or was this a purchased, precut, line?
If precut, you may want to take it off and check to see if the mating surface is good.
If it is one you made, you may want to run the second crimp again to make sure the surface is good.
Use flare-nut wrenches when tightening those fittings.
