Old 08-23-2004, 02:56 PM
coyled coyled is offline
Clois, make sure the races are seated. Then check the id of the bearings against the od of the spindle. My wheel bearings never felt correct to me. It would drive me nuts. I would adjust them properly, put the wheel on and it would feel like the bearings are loose. I would recheck it and they were adjusted properly but were still loose. You never want a bearing to tight. A little loose is better than too tight. I finally measured and figured out that the id of the bearings were 1.380 (I think) and the od of the spindle was 1.375 . That .005 difference was enough to make it feel a bit loose even after I adjusted it properly. I changed the bearings and now it is perfect. Good luck, Scott.
