Thread: Angle Mill Help
Old 08-25-2004, 11:36 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
What is your general goal here?
I mean, it sounds like you have a CAM that is dictating the engine build.
Think about the fuel you are using. If you are out for premium fuel, then 10 to 1 or better. Get a piston that forces that much compression with your heads. Milling heads for compression is a bit rough in todays market.
Start out with a list of wants.
Stop entering all these problems into the mix. Get a block. Pick a piston that will give you your desired compression. balance and blue print the assembly.
Personally I would work with the heads as they are and unmolested. You can build that top fueler after you have this one under your belt.
Just my $0.02
