Old 08-26-2004, 05:26 AM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Default Lift-A-Dot install
I am currently installing a soft top using lift-a-dots. My question is regarding the post that goes into the lift-a-dot. My posts can unscrew from their base so they can be removed when the top is off.
Does the base just get pressed into a predrilled hole. It seems like they may pull out over time. I also have the posts that just screw into a pilot hole. Are those better?
Thanks
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
