Old 08-26-2004, 03:14 PM
MetaJacko's Avatar
MetaJacko MetaJacko is offline
Cobra Make, Engine: Metaline 1969 Ford 390 bored to 402ci
Default Re: Harland Sharp makes heavy duty rocker shafts.
Originally posted by jared1970
Just because your pushrods don't have oil passages ...
Thanks for the info, ill check the lifters.
Originally posted by chuckbrandt
You can buy them from summit and unless you have a really high lift / high spring rate cam, they should fix your problem.
Chuck
Link To Harland Sharp Rocker Shafts at Summit
Hopefully this should solve my replacement rocker shaft problem.
If I can, I think getting end supports sounds a good idea.
Are they a bolt on replacement for the current end support
IE the one that is just before the last rocker and basically do
both sides?
If not how difficult are they to fit usually?
Anyone have any suggestions about where to get new push rods?
Paul
