Old 08-27-2004, 12:45 PM
SSSnake's Avatar
SSSnake SSSnake is offline
Cobra Make, Engine: ERA FIA #2078. 331 stroker, sportsman block built by Evanuik Performance. 450hp
Send a message via AIM to SSSnake
We drilled out the holes and put nutserts in the body. It required some extra sanding to get the nutserts flush with the body, and we used the machine thread posts from cobra restorers. If you wanted to remove the posts, you can insert some stainless set screws to fill the holes. We had them in while painting the car, and i must say it didnt look bad.
Glenn
